Coming back to Scilab after a long time, I’ve started updating some old project. In particular, a tool aimed at simplifying the process of formulating optimisation problem.
It started from my curiosity concerning Yalmip on matlab and while it may not reach the same level, I still have good hopes to make it useful.
For the time being, it is able to parse linear problems and solve them with a builtin simplex (that I would not fully trust) or scilab interior point karmakar. For instance,
I have added some basic support for piecewise affine problems that can be converted to LP problems.
For instance:
sopi_begin;
n = 3;
W = rand(n,n);
d = rand(n,1);
xMax = 5*rand(n,1);
A = rand(2,n);
b = 20*rand(2,1);
// Problem formulation
x = sopi_var(n);
LB = x >= 0;
ci = A*x <= b;
ce = x(2) == xMax(2);
fun = norm(W*(x - d),1);
problem = sopi_min(fun,list(LB,ce,ci));
// Problem resolution
[xopt, fopt] = sopi_solve(problem,'sopilp');
[norm(W * (xopt.x - d),1), fopt]
Welcome to Scilab’s Discourse and thanks for this initiative ! Could you quickly list the type of optimization problems that you currently consider and the Scilab solvers you plan to use ?
On the modelling side: Currently, the following problems should be correctly parsed:
linear problems,
convex piecewise affine problems, i.e. problems involving max/abs of linear elements.
In a somewhat short term, I will add support for
quadratic problems: quad. objective and linear constraints,
and everything that does not fit above will fall as general “non-linear” problem. Supported functions (scalar mainly) will be added incrementally. The idea is to generate scilab code for the associated non-linear functions/constraints (and their derivatives) to feed the solvers.
In the longer term, I may add support for:
shades of convex problems, e.g. : SOCP, SDP,
integer variables
extend the support for “exotic” matrix operations or functions
On the solver side: I only plan to interface with available solvers (and write some, but that is for fun) hence it is quite fast to do:
linear problems: karmarkar, linpro (from atoms, I have the interface but the install fails at the moment)
convex quadratic: qld, qp_solve, quapro (from atoms, same issue as above)
SDP: semidef
unconstrained NLP: optim_qn/gc/nd
box constrained NLP: opim_qn/gc
every NLP in general: sci-IPopt (from atoms)
Actually, I am not aware of the status of each optimisation package on atoms, so this may change. Since you are (or have been) involved in a number of those packages, you may have some insights on this point?
