Hi Scilab team,
I have a understanding problem with champ.
When i run champ in a loop it draws me every single arrow (3 arrows). But when i do it as one vectorized command it says wrong size. (it expects 9 arrows i presume)
CURL-Weather.sci (8.4 KB)
Hi Scilab team,
Hi @pascal
You are right, champ requires a grid in this case.
Using xarrows should work in your case.
Thanks for the reply, i will try it wit xarrows
M.f.G. Pascal
